Need help fixing issues with the Shopsy App
I’m having ongoing issues with the Shopsy App, like slow loading, random crashes, and orders not updating or syncing properly. I’ve tried reinstalling and clearing cache, but nothing seems to work. I need advice on what else I can do to fix these problems or if there are any known bugs or workarounds I should try.
Had similar issues with Shopsy a few weeks ago. Slow screens, random crashes, orders stuck or not syncing. Here is what helped, step by step.
  1. Check version and device
    • Make sure you are on the latest Shopsy app version in Play Store or App Store.
    • If you use an older phone with low RAM, keep other apps closed. Shopsy eats memory and then crashes.
  2. Clear more than cache
    You said you cleared cache. Do this too:
    • Log out of the app.
    • Go to app settings on your phone.
    • Force stop Shopsy.
    • Clear storage / data, not only cache.
    • Restart the phone.
    • Log back in and let it sit for 1 to 2 minutes so it syncs.
  3. Check network side
    A lot of order sync issues come from weak or unstable network, not from the app only.
    • Test on both WiFi and mobile data.
    • Turn off VPN, ad blocker, DNS apps.
    • Try again at a different time of day, Shopsy servers slow down at peak hours in some regions.
  4. Orders not updating or missing
    This part annoyed me the most.
    • Cross check your orders in three places: Shopsy app, Shopsy website in a browser, and your email or SMS.
    • If the order status on web differs from the app, it is usually a sync bug on the app.
    • Take screenshots of the order ID, timestamps, and status from both app and web.
  5. Background limits on your phone
    If you use Android with aggressive battery saving, it kills Shopsy in the background.
    • Go to Settings → Battery → Battery optimization.
    • Remove Shopsy from “optimized” or restricted list.
    • Allow Shopsy unrestricted data or background data.
    This stopped a lot of my random logouts and half loaded screens.
  6. Turn off auto translate or accessibility overlays
    If you run screen readers, floating chat heads, or screen filters, some versions of Shopsy crash when overlays are on.
    • Disable those tools for a short test.
    • If the crashes stop, you found the trigger.
  7. Reinstall with a “clean” network
    Weird trick that helped me:
    • Uninstall Shopsy.
    • Connect to a different WiFi or use mobile data.
    • Reinstall and log in fresh.
    Something in the old CDN routing or cache was messed up, this reset it.
  8. Check known outage
    Before fighting the app for hours:
    • Search “Shopsy app down” on Twitter or Downdetector style sites.
    • If lots of users report slow or crashing app, the issue sits on their side, not yours.
  9. Contact support with useful data, not “it is slow”
    When you contact support, send:
    • Device model and OS version.
    • App version number.
    • Approx time of the last crash.
    • Steps you took before it crashed, for example “opened Orders, tapped View Details, app closed”.
    • Order IDs that do not sync or update.
    When I sent that kind of detail, they escalated it instead of sending copy paste answers.
  10. Temporary workaround for orders
    Until it gets stable:
    • Place and track orders through the Shopsy website in a browser, not the app.
    • Use the app only for browsing, not final checkout.
    This reduced my failed or stuck orders a lot.
If none of this changes anything after a day or two, I would:
• Test on a different phone with your account.
• If it runs fine on the other device, your phone setup is part of the issue.
• If it breaks the same way, your account might be flagged or bugged on their backend, which support needs to fix.
Yeah, it is annoying. Took me like three evenings of trial and error to get it stable enough to trust it for orders again.
I’ll be a bit contrarian to @cazadordeestrellas on one thing: if you’ve already reinstalled multiple times and done the usual cache / data dance, you might be hitting account‑level or region/server issues more than device stuff.
Here’s what I’d try that’s different from what was already suggested:
  1. Isolate whether it’s your account or your phone
    • Log in to your account on a different device (friend’s phone, spare phone, even an emulator on a PC if you’re into that).
    • If the same slow loading, order sync issues and crashes happen there, that screams backend/account problem, not your device.
    • If it runs smooth on the other device, then yeah, something in your current phone’s system config is messing with it.
  2. Test a “dummy” account
    • Temporarily create a new Shopsy account (different email / phone).
    • Use it on the same phone where you have issues.
    • If the new account works fine but your main account is a mess, support needs to fix flags / corrupted profile / buggy order history on their side.
    • If even the dummy account is laggy and crashes, your device / OS / local network stack is the suspect.
  3. Narrow down what actually triggers crashes
    Don’t just note “random” crashes. Try to see patterns:
    • Only when opening Orders?
    • Only when viewing a specific order or seller?
    • Only when using search filters, or when scrolling long product lists?
      If you find a repeatable step like “open Orders → scroll to past orders → app closes,” that’s gold for support and also lets you avoid that flow and use the web version for that specific action.
  4. Check storage & system health, not just RAM
    • If your phone’s internal storage is nearly full (like >90%), apps get sluggish and unstable because they can’t write temp files properly.
    • Try freeing 2–3 GB of space and then test again.
    • Also, if you use “lite” or “cloned app” tools (dual apps, parallel space, etc.), avoid running Shopsy there. Those envs are bug factories.
  5. Turn off “smart” network features
    This is different from just switching WiFi/data:
    • Disable “Data saver” and any “smart network switch” or “dual channel acceleration” type feature. Some vendors’ network optimizations break request timeouts and make sync look buggy.
    • If your router uses aggressive DNS filtering or “safe browsing,” temporarily switch your phone’s DNS to something plain like 8.8.8.8 and test again.
  6. Time-based testing for order sync
    Since orders not updating is your big issue:
    • Place a very cheap test order.
    • Track the exact timestamps: app status vs web status vs SMS/email, in the first 30–60 mins.
    • If the app is consistently behind the web by 15–20 minutes or shows stale data even after force-closing and reopening, that’s not “your phone,” that’s a sync layer bug or crappy caching from their side.
  7. Get noisy, but with evidence
    When you contact support, don’t just send device + crash time like @cazadordeestrellas suggested. Attach:
    • Screen recording showing the app freezing or crashing, including the clock and steps.
    • Screenshots where web shows “Shipped” but app shows “Processing” for the same order ID.
    • Mention that you tested:
      • another device with your account
      • another account on your device
        When they see you’ve eliminated device issues yourself, it’s harder for them to blame “clear cache / reinstall” and close the ticket.
  8. Temporary setup that actually reduces pain
    Instead of only using the website for checkout, I’d flip it:
    • Browse casually in the app if it loads;
    • Once you’re ready to actually buy or track, do all critical stuff in a browser (preferably in incognito/private mode to avoid weird cookies).
      That way, any crash doesn’t risk your cart or payment flow.
If after doing the account/dummy account tests it’s clearly tied to your account, keep pushing support and explicitly say:
“The same problems occur with my account on multiple devices and networks, but a different account on the same device works fine. Please check my account configuration or order history indexing on your backend.”
That wording usually gets you past the first-line “please clear cache” script. And yeah, a lot of what you’re describing smells more like their infra choking than your phone magically being cursed.
Both @codecrafter and @cazadordeestrellas covered the “standard” device / network / account debugging really well. I’d look at a few angles they did not focus on, especially if the Shopsy App is part of your regular shopping workflow and not just an occasional install-and-forget app.
  1. Check if Shopsy App issues correlate with system-wide instability
    If other heavy apps (large e‑commerce, banking, map apps) randomly stutter, Shopsy might just be the first one to show cracks.
  • Run a basic hardware test: long browsing session in a browser plus one more heavy app.
  • If everything else is fine while Shopsy keeps choking, that leans toward Shopsy’s own build quality or your particular combination of OS + vendor skin.
  1. Don’t overdo “app cleanups”
    Here I’ll mildly disagree with how aggressive clean‑up sometimes gets interpreted from advice. Constantly nuking data can cause:
  • Repeated full sync each launch, which can worsen slow loading and order refreshing.
  • More chances of partial sync if the app is closed mid‑load.
    Try this instead: stabilize your environment once, then stop touching it for a week and just observe.
  1. Watch for UI thread blockers (animation / media heavy pages)
    Crashes during scrolling or product browsing often hint at:
  • Overloaded product pages with video, GIFs, auto‑play promos.
  • Heavy “infinite scroll” lists.
    Test:
  • Switch to a lighter view if available, like list instead of grid.
  • Avoid auto‑playing carousels at the top. If the crash frequency drops, it is less about network and more about how Shopsy App handles rendering on your hardware.
  1. Use browser dev tools as a diagnostic
    On a PC or laptop, open the Shopsy website, log into the same account, open dev tools → Network tab, then:
  • Perform the same actions that are slow on mobile (order refresh, search, filters).
  • Watch if requests are taking very long or returning errors.
    If the desktop web also shows erratic timings or a lot of 5xx/4xx, that is a backend or regional infra issue, not your phone.
  1. Region & language combinations
    Shopsy App sometimes behaves differently depending on:
  • App language vs system language.
  • Region‑specific promos or modules.
    Try:
  • Temporarily switching system language to English only, then restarting Shopsy.
  • Turning off VPN / DNS trickery and ensuring your region in the app matches your actual location.
    Glitches here can cause half‑loaded pages and desync for localized order flows.
  1. Limit Shopsy’s “smart” features
    Even without disabling overlays like @cazadordeestrellas suggested, you can:
  • Turn off in‑app chat if it exists or reduce notification categories.
  • Disable auto‑play video and rich previews in settings if the app offers it.
    Less live content can equal fewer chances to hit the buggiest parts of the code.
  1. Workaround pattern for order reliability
    Until the Shopsy App becomes stable for you, a more cautious hybrid pattern helps:
  • Use the app only for low‑risk actions like browsing, checking prices, or reading reviews.
  • For any critical step (place order, cancel, return, payment, address changes), switch to the website in a mobile browser.
    That reduces the cost of each crash while you and support figure out the root cause.
  1. When you escalate to support, frame it as a reproducible scenario
    Using what @codecrafter said about recordings, make your message almost like a bug report:
  • “On Android 13, Shopsy App 5.x, when I open Orders with more than 50 past orders, scroll fast for 10 seconds, then open a recent order, the app closes.”
    Support teams respond far better to that than general “it’s laggy,” and it helps them tie your case to known internal tickets.
As for the Shopsy App itself, pros and cons from a user perspective, especially in your situation:
  • Deep integration with Shopsy’s backend so once it behaves, order tracking, notifications, and offers can be more convenient than browser use.
  • Usually faster sign‑in and checkout flow than the mobile site when the app is healthy.
  • Offline caching can make product browsing snappy on stable devices.
  • Sensitive to device, OS version, and vendor skin mismatches, which can cause exactly the crashes and slow sync you are seeing.
  • Sometimes lags behind the website for order status, so “Processing” in app vs “Shipped” on web is not rare.
  • Heavier on resources than a simple browser tab, which punishes mid‑range or older phones.
Compared to what @codecrafter and @cazadordeestrellas proposed, I would avoid spending endless time reinstalling and clearing data once you have done it a couple of times. At that point your best leverage is:
  • Reproducible patterns.
  • Clear separation of account vs device vs region issues.
  • Strategic use of the browser as your “safe mode” for Shopsy until their side stabilizes.
