Need help understanding how to use Deevid Ai effectively
I just started using Deevid Ai and I’m confused about how to get the best results from it. The features and settings aren’t very clear to me, and I’m not sure if I’m setting things up correctly for my use case. Can someone explain how Deevid Ai is supposed to work, what the main features are, and share any tips or best practices for beginners so I don’t waste time using it the wrong way?
Short version first, then details.
  1. Start with one clear goal
    Ask yourself: “What do I want from Deevid AI right now?”
    Examples:
    • Turn a long video into shorts
    • Generate a script from a topic
    • Make social clips with captions
Stick to one goal per project. The tool tends to work better when you give it a narrow job.
  1. Feed it the right input
    If you upload video:
    • Use clear audio, minimal background noise
    • Prefer horizontal 1080p if you want vertical shorts later
    • Keep files under their size limit or split them
If you use text prompts:
Use a format like:
“Task: Create 5 short YouTube clips.
Source: [link or notes].
Audience: Beginner marketers.
Tone: Casual, direct.
Length per clip: 30–45 seconds.
Output: Include hook, main point, CTA.”
Avoid vague stuff like “make this better” or “make it viral”.
  1. Learn the presets and templates
    Most of these tools have:
    • Style presets: “educational”, “TikTok style”, “talking head” etc
    • Aspect ratios: 9:16, 16:9, 1:1
    • Caption styles and fonts
For performance on TikTok / Reels:
• Use 9:16
• Big captions at bottom or center
• Duration 15–45 seconds
• Add a clear hook in first 2–3 seconds
For YouTube long form:
• 16:9
• Keep jump cuts modest
• Use calmer captions or none
  1. Control the AI with constraints
    Instead of “make a video on X”, try:
    • “Script length: 120–150 words”
    • “Max 3 main points”
    • “No buzzwords”
    • “Use simple language at 7th grade level”
    • “Address the viewer as ‘you’”
The more constraints you add, the more consistent the output.
  1. Use an iterate test loop
    One full cycle:
    • Generate first version
    • Watch once without editing, note issues
    • Tweak only 1–2 things per round:
    – Change hook
    – Shorten length
    – Adjust captions or b-roll style
Export a short sample and test it with:
• A/B upload titles and thumbnails
• Watch retention graph in YouTube or TikTok analytics
If drop-off happens in first 3 seconds, fix the hook, not the rest.
  1. Use examples as “style guides”
    Upload or link a reference video you like.
    Then prompt like:
    “Make my video follow this pacing: [reference link].
    Short sentences. Fast cuts. Text emphasis on key words only.”
If Deevid has “copy style” or “inspire from this video”, use that and still add written constraints.
  1. Tweak common settings
    These differ a bit per app, but typical safe defaults:
    • Auto-captions: ON
    • Caption speed: 0.8–1.0x speech speed
    • Transitions: minimal, 1–2 types only
    • Music volume: 5–15 percent under voice
    • Auto zoom / movement: low to medium
If your video looks noisy or chaotic, reduce:
• Transitions
• Emojis
• On-screen text elements
  1. For different use cases
For educational explainer:
• 16:9 or 9:16, depending on platform
• Clear structure: “Problem – Why it matters – Steps – Summary”
• Ask it: “Number the steps, use short bullets.”
For product or SaaS demo:
• Screen recording + short script
• Ask: “Highlight cursor moments. Zoom in on UI at important clicks.”
For UGC style social content:
• Casual tone
• Slight camera movement is ok
• Ask: “Make me sound like I’m talking to a friend. No corporate phrases.”
  1. Keep your own “prompt templates”
    Once you find a prompt that works, save it.
    Example template you can adapt:
“Role: You are a video editor for short-form social content.
Task: Turn this source into 3 vertical clips.
Audience: [describe clearly].
Tone: [e.g. calm, confident, casual].
Length: 20–35 seconds per clip.
Structure:
  1. Strong hook sentence.
  2. 1 to 3 clear points.
  3. Simple CTA at end.
    Rules:
    • Use simple language.
    • No long sentences.
    • Add on-screen text only for key phrases.
    • Match captions to spoken words exactly.”
  1. If results look “off”
    Typical issues and quick fixes:
Output feels generic
→ Add target audience, level of knowledge, and 1–2 specific pain points.
Video too long
→ Add a word or second limit, and “cut any fluff”.
Captions look messy
→ Set one font, one color, one style, turn off extra animations.
  1. Learn from analytics, not vibes
    Pick 1–2 metrics per platform:
    • YouTube shorts: average view duration, retention curve
    • TikTok: watch time, completion rate
    • Instagram: replays and shares
Change one variable at a time: hook, length, or style. Then see what changes.
If you share what you want to use Deevid AI for, like shorts, long form, ads, or tutorials, people here can share exact prompts and settings that tend to work.
Skip the “learn every feature” mindset. Deevid (and similar tools) get less confusing if you treat them like a stubborn junior editor instead of a magic button.
A few things that complement what @byteguru said, not repeat it:
  1. Start from your distribution first
    Before you touch Deevid, answer:
    • Where will this go: YouTube, Shorts, TikTok, Reels, LinkedIn?
    • How often: daily, 3x/week, once a month?
    • What format: talking head, b‑roll with voiceover, screen demo?
    Then go into Deevid and build one “pipeline” that matches that. For example:
    • “TikTok pipeline” = vertical, 20–35s, loud captions, punchy music
    • “YouTube longform pipeline” = horizontal, calmer text, slower cuts
    Save those as reusable presets / projects instead of rethinking settings every time.
  2. Use Deevid’s mistakes as configuration hints
    Instead of asking “why is this bad?” ask “what setting did this reveal?”
    Common patterns:
    • It keeps cutting mid sentence
    → Your auto-cut / highlight-detection sensitivity is too high. Turn that down or switch to “cut by silence” only.
    • Weird random b‑roll
    → Turn b‑roll suggestions off, or limit it to specific keywords you define in the prompt.
    • Captions out of sync
    → Manually adjust caption offset once, then save that timing preset for that recording setup (some mics and cameras drift slightly).
  3. Build a fixed workflow and stick to it for 10 videos
    Example “minimum-brain” workflow:
    1. Record raw video
    2. Drop into Deevid with your ready-made preset
    3. Let it auto-generate
    4. Only touch 3 things: hook, captions layout, background music level
    5. Export and publish
    Do not change 15 toggles every time. Run the same workflow for a batch of 10. After 10, look at what consistently annoyed you, then adjust that one part in the preset.
  4. Turn off stuff you do not actually need
    A lot of these tools look “powerful” but half the visual chaos is from default-on features:
    • Emojis everywhere
    • Random zooms
    • Over-animated captions
    • Stock b‑roll over your face when you are making the key point
    For a clean start, try this brutal approach:
    • All transitions off
    • Auto zoom off
    • Emojis off
    • No b‑roll
    • Simple static captions only
    Then add back one thing at a time (like minor zooms or 1 text effect) until it looks alive but not like a slot machine.
  5. Create “role cards” for Deevid instead of generic prompts
    Everyone says “be specific,” but you can simplify that by making 2–3 canned “roles”:
    • “You’re a ruthless short-form editor”
    Rules: cut anything that is not a hook, example, or payoff, keep final under 30s, no intro fluff.
    • “You’re a patient teacher”
    Rules: keep pacing slower, add on‑screen labels for key terms, no flashy effects, keep structure: what, why, how.
    • “You’re an ad editor”
    Rules: highlight benefits with text, one big hook at start, one clear offer at end, cut every dead pause.
    Then call these roles in your prompt instead of rewriting everything every time.
  6. Decide what you won’t use Deevid for
    Unpopular opinion: do not try to let the tool do 100% of the work. It is bad at a few specific things:
    • Nuance in jokes and timing (you will usually cut those better manually)
    • Very precise storytelling beats
    • Brand design consistency at a pixel-perfect level
    So for those, use Deevid to rough cut and caption, then do a final tiny cleanup in a normal editor if you care about polish. You will get better results than fighting the settings forever.
  7. Quick sanity checklist per project
    Before you click “export,” literally run through this list:
    • Did I check the first 3 seconds and ask “would I keep watching?”
    • Are captions readable on a small phone screen?
    • Is the music clearly below my voice?
    • Did I accidentally leave 5 different text styles in one video?
    Fix only what breaks those four. Ignore everything else until you have more experience.
If you share what type of content you are making (educational, gaming, coaching, SaaS, etc.) and where you are posting, people can probably tell you exactly which 3–4 settings in Deevid you should lock in and forget about for now.
Short, no-nonsense angle on using Deevid Ai effectively, without repeating what @yozora and @byteguru already covered.
Where I slightly disagree with them
They both focus a lot on prompts, roles, and templates. That is useful, but Deevid Ai is still a video tool first, so your biggest wins usually come from:
  1. Fixing how you record
  2. Locking in a simple “one-click” preset
  3. Being brutal about what you do outside Deevid
1. Start “outside” Deevid: record with editing in mind
If you’re confused by settings, simplify life before you ever upload:
  • Record in short segments, not one giant 40-minute take.
    Deevid will cut cleaner when each segment has a clear start and end.
  • Clap or pause clearly when you switch topics.
    That creates natural cut points the AI can detect.
  • Keep background simple and quiet.
    Cleaner visuals and audio = fewer weird auto-choices from Deevid Ai.
This matters more than any clever prompt.
2. Create exactly one “dumb preset” and stick to it
Instead of hunting through every feature:
  1. Create a project in Deevid Ai with:
    • One aspect ratio you actually use (9:16 for shorts or 16:9 for YouTube)
    • One caption style (font, color, position)
    • Music default at low volume
  2. Save it as something obvious like:
    • “Daily Shorts – Simple”
  3. Use this only for the next 10 videos.
    Do not tweak every time. If something annoys you in 5 out of 10 exports, then adjust the preset once.
This is where I’d go simpler than what @yozora and @byteguru suggest. Over-optimizing each video at the start just burns time and makes Deevid Ai feel more confusing.
3. Use Deevid Ai as a “first pass,” not final authority
Treat Deevid Ai like a rough-cut engine:
  • Let it auto-generate the edit and captions.
  • Fix only these three things before exporting:
    1. First 3 seconds (hook or opening frame)
    2. Any obvious cut that feels jarring
    3. Caption readability on a phone screen
If you care about polish, do a 5-minute cleanup in a classic editor after export instead of trying to wrestle every detail inside Deevid.
4. Pros & cons of using Deevid Ai this way
  • Huge time saver for cutting, captioning, and formatting for platforms
  • Easy to batch process multiple clips once your preset is solid
  • Good enough for most social content without needing pro editing skills
  • Lets you focus on script and performance instead of timeline work
  • Visual style can feel generic unless you lock in consistent branding
  • Auto b-roll and effects can look chaotic if you leave too many toggles on
  • Not great for very precise comedic timing or cinematic storytelling
  • You may still want a final pass in another editor for high-end projects
5. How this compares to the other replies
  • @byteguru gives an excellent “control through constraints” approach. Great once you’re comfortable.
  • @yozora focuses on strategy, distribution, and roles, which is powerful but a bit advanced if you are still lost in the interface.
If you are just starting and feel confused, ignore half the knobs in Deevid Ai, build that one simple preset, and only improve it every 10 videos. That pattern alone will usually get you from “overwhelmed and random” to “consistent and good enough” surprisingly fast.
