I’ve been experimenting with different AI art tools to generate cartoon images, but my results feel generic and repetitive. I’m not sure which keywords, art styles, or artist references work best for getting unique, high‑quality cartoon looks. Could anyone share examples, tips, or a list of effective cartoon styles and phrases I can use to improve my AI prompts for illustration, character design, and storytelling images?
Short version. Your prompts sound like they need more specificity and less “AI art buzzwords”.
Here is a practical way to push your cartoon styles past the generic stuff.
Steal structure from real artists
Open Pinterest, Artstation, Behance, comics, animation frames.
Pick 5 to 10 artists or shows. Example
• Genndy Tartakovsky (Samurai Jack, Primal)
• Bruce Timm (Batman TAS)
• Ghibli background painters
• Craig McCracken (Powerpuff Girls)
• Laika stop motion stills
For each one write in plain text
• Line weight: thick / thin / varied
• Color: flat / cel shaded / painterly / neon / pastel
• Shapes: angular / round / long limbs / big heads
• Detail: simple / busy / textured
Now you have a style vocabulary. Feed that into prompts instead of “cartoon style”. -
Replace vague tags with concrete traits
Weak: “cartoon, cute, 2D, Pixar style”
Stronger:
“2D hand drawn look, thick black outlines, flat colors, limited palette of teal, orange and cream, large eyes, tiny nose, exaggerated squash and stretch, simple backgrounds, clean vector style, no gradients”
Break it into
• Line
• Color
• Shapes
• Rendering
• Camera
• Medium
- Use “in the style of” smarter
Do not stack 10 famous names. Models mash them into mush.
Try patterns like
• “inspired by Bruce Timm, flat cel shading, bold silhouettes”
• “inspired by Genndy Tartakovsky, minimal detail, strong shapes, high contrast lighting”
• “inspired by UPA cartoons from the 1950s, graphic shapes, limited animation feel, textured paper”
Then do the opposite run
• “no Pixar, no Disney, no Dreamworks, no 3D, no photorealism”
Force a unique visual hook per series
When you start a “project” or character set, pick 2 or 3 fixed rules.
Examples
• Only 2 main colors per image
• Backgrounds use isometric perspective
• Characters have triangle heads and square hands
• Outlines are deep purple instead of black
Add stuff like
“series style, consistent look, same visual rules, triangle heads, purple outlines, limited palette of red and beige, simple flat backgrounds” -
Describe camera and composition
Most people skip this, so results feel flat. Try
• “wide angle lens, low camera angle”
• “top down shot, tiny character in large environment”
• “close up portrait, centered composition, plain background”
Cartoon plus strong composition looks less generic. -
Mix media keywords
You can push away from the “AI mush” look with physical media prompts.
Examples
• “gouache on textured paper, visible brush strokes, rough edges, imperfect registration”
• “marker sketch, visible overlapping strokes, rough line art, white paper grain”
• “screen print style, 3 color print, slight misalignment, halftone dots”
Combine with cartoon pointers
“simple cartoon character, screen print style, 3 flat colors, thick line art, paper texture”
- Prompt structure cheat sheet
Try this template and swap content each time
Subject:
“full body cartoon of a nervous office worker holding a huge coffee cup”
Style block:
“2D hand drawn look, thick black outlines, large round eyes, small mouth, big head, short body, flat cel shading, limited palette of blue and beige, simple background, no gradients, paper texture”
Camera block:
“medium shot, straight on camera, centered composition, empty office background”
Negative block:
“no 3D, no photorealism, no realistic lighting, no extra limbs, no text, no watermark”
Iterate like a designer, not like a slot machine
Run small batches.
Each time, only change 1 or 2 words.
Save your best prompt variants in a text doc. Treat them like presets.
Example of edits
v1: “flat colors”
v2: “flat cel shading, high contrast shadows”
v3: v2 plus “angular shapes, sharp elbows, pointy chins” -
Study what works from other people’s prompts
On sites like Civitai, Lexica, Reddit etc look for cartoon prompt posts.
Copy a full prompt, run it, then swap subject and color words.
Keep the camera and style part for testing.
You learn faster than trying random buzzwords. -
Avoid overstuffing
If your prompt looks like
“Disney, Pixar, Ghibli, anime, Dreamworks, Looney Tunes, photoreal, oil painting, cyberpunk, steampunk, vaporwave, synthwave, kawaii, 4K, 8K, ultra detailed”
then yeah, it will look like melted soup.
Pick a small set of style ideas and stick to them.
If you share one of your current prompts, people here can help refactor it into something less generic and more repeatable.
You’re not just fighting “bad prompts,” you’re fighting “model defaults.” A lot of models have a baked‑in idea of “cartoon” that they’ll snap back to unless you actively pull them away from it.
@hoshikuzu covered structure really well, so I’ll try to hit different angles and argue with a couple of their points a bit.
1. Stop chasing “unique” with more style words
People often think: “This looks generic, I should add more styles.”
So they stack: Disney + Pixar + Ghibli + anime + Looney Tunes + vaporwave etc.
That doesn’t create a new style, it creates a tug‑of‑war. The model averages everything out into the safest look it can.
Instead of asking “what other keyword can I add,” ask “what can I remove so one idea dominates.”
Try this experiment:
- Take one of your usual prompts.
- Remove every style word except:
- 1 medium (ex: “flat cel shading”)
- 1 vibe (ex: “retro 90s TV cartoon”)
- 1 surface/texture (ex: “printed on slightly yellowed paper”)
- Keep it that way for 10–20 images and only tweak content, not style.
You’ll get a more consistent, less mushy look, even if it’s still simple at first.
2. Build a “cartoon logic” sheet, not just a style list
I disagree slightly with overfocusing on line/shape/color first. You can get further by deciding the rules of your world before the visuals.
Fill out a tiny “cartoon logic” doc for your series:
- Physics:
- Realistic, or squash and stretch, or totally floaty?
- Can limbs bend wrong? Faces morph like rubber?
- Expression range:
- Subtle or wild? Giant mouths, bulging eyes, sweat drops?
- Humor level:
- Slapstick vs deadpan vs melancholy.
- World scale:
- Tiny characters in huge spaces, or cramped, busy frames?
Then convert that logic into visual instructions:
“Slapstick cartoon physics, limbs stretch like rubber, huge open mouths, eyes pop out slightly, exaggerated motion lines, mid‑air freeze poses”
This gives the model a behavioral language, not just “thick lines, flat colors.”
3. Use contrasts instead of artist name-dropping
Artist references help, but if you do not know what exactly you like from them, you’re guessing. Instead of “inspired by X,” try describing visual contrasts:
- “Cute characters in harsh, moody lighting”
- “Simple faces, insanely detailed props”
- “Tiny pupils inside huge white eyes, blank wide stare”
- “Soft pastel colors with violent action poses”
Giving the model a contradiction (“cute but threatening,” “soft but chaotic”) quietly forces it to push beyond generic “cartoon = bright, friendly, balanced.”
4. Design one element to be ‘weird’ on purpose
Generic AI cartoons happen when every decision is “safe average.” Pick one element and crank it way off center:
Examples:
- Heads are small but hands are huge and blocky
- All backgrounds are monochrome silhouettes
- Eyes are always drawn as hollow circles with no pupils
- Every character has a single bold symbol on their clothing
Prompt like:
“simple cartoon character, extremely oversized square hands, small head, eyes are hollow circles without pupils, clothing always has a single large circular emblem on the chest, flat cel shading, muted pastel palette”
You’re not just styling, you’re branding the look.
5. Reference genres and eras instead of specific studios
I’d actually go lighter on “no Pixar / no Disney” unless the model keeps defaulting there. Sometimes hard negatives break good lighting or appealing expressions.
Try:
- “early 2000s Cartoon Network bumpers style, graphic shapes”
- “1990s newspaper comic strip style, simple inking, limited crosshatching”
- “1960s Eastern European animation, flat cutout shapes, weird compositions”
- “cheap 80s Saturday morning cartoon, off‑model faces, irregular linework”
Eras and production qualities hint at imperfections, which AI usually avoids and that’s often what makes your result feel too clean and bland.
6. Bake “imperfection” into your prompts
Most models overpolish. Your cartoon starts to look like stock clipart.
Add a bit of controlled “wrongness”:
- “slightly off‑register colors”
- “subtle wobble in linework, like drawn by hand”
- “uneven line thickness, occasional gaps in the outline”
- “misaligned perspective, intentionally naive drawing style”
That combo can break you out of the AI‑clipart feel fast.
7. Iterate per series, not per single image
Instead of: “I will get the perfect style for this one prompt,” do:
- Decide a mini project: “office goblins,” “sad robots,” “witch roommates”
- Lock style rules for that project, even if they’re not perfect
- Generate 20–50 images under that rule
- Analyze what actually looks cool across them
- Maybe the faces are meh, but the backgrounds are nice
- Or vice versa
Then on the next series, upgrade your rules. Treat each set like a season of a show where the art slowly evolves.
8. Steal from bad art, not just good art
Everyone studies the same big names. Try searching stuff like:
- “amateur webcomic 2005”
- “old flash game character art”
- “MS Paint comic”
Look at what’s charming about the roughness, and call that out in the prompt:
“awkward but charming webcomic style, clumsy proportions, uneven outlines, simple flat colors, slightly goofy anatomy, minimal shading”
Models often produce “so bad it’s good” results when you give them permission to not be perfect.
9. Lock down recurring design motifs
Ask yourself: “If someone saw 10 of my images on a wall, what repeating thing would tell them it’s the same ‘universe’?”
Then define 2 or 3 motifs, for example:
- A recurring icon (stars, triangles, spirals, broken halos)
- Repeated pattern (checkerboard shadows, diagonal stripes, halos behind heads)
- Color rule (all shadows are purple, all highlights are mint, skies are always teal)
Prompt like:
“same universe style, recurring visual motif of small white halo behind every character’s head, all shadows tinted purple, sky always a flat teal gradient, simple cel shading”
That coherence alone will make the style feel more intentional.
10. Post‑process is allowed
You can get a lot of “style” by accepting a somewhat generic base and then:
- Slamming it through a heavy posterize filter
- Dropping saturation, then punching one color back up
- Adding noise, halftone, or photocopy textures
- Slightly warping or liquifying shapes
Then, once you know what kind of post‑processed look you like, describe that look back into your prompts:
“looks like a photocopied zine, high contrast, crushed blacks, rough halftone dots, slight distortion at the edges”
The model often lands closer to your post‑edited output.
If you’re up for it, paste one of your current “cartoon” prompts and one result you consider generic. It’s usually pretty quick to spot the 2 or 3 habits that are making the model fall back into that same safe style every time.
Skip the “magic keyword” hunt for a second and think like a showrunner, not a prompt hacker.
Where @hoshikuzu leaned into logic and structure, I’ll push you toward art direction and process.
1. Design a style guide outside the AI first
Open a doc and answer visually concrete questions before you touch the model:
- Line:
- Are outlines always black, or colored?
- Thick contour with thin interior lines, or all uniform?
- Proportions:
- Heads vs bodies ratio: 1:1, 1:2, chibi?
- Hands, feet, necks: underdrawn or exaggerated?
- Color:
- Max colors per character (for real, pick a number: 4, 6, 8).
- Are shadows a darker local color or a weird hue (purple, teal)?
- Rendering:
- No gradients at all?
- Only one hard cel‑shade layer?
Then, convert this into instructions, for example:
bold black contour lines with minimal interior detail, 1:1 head to body ratio, hands slightly oversized, strictly flat colors, no gradients, only one hard cel shadow layer in purple
You can reuse that block across prompts. That repeatability is what kills the “generic” feel over time.
2. Stop using “cartoon” as a core word
Here I’ll disagree a bit with the idea of only pulling away through subtle shifts. In a lot of models, the token “cartoon” is basically a trap that yanks you back to stock clipart.
Try prompts that never say “cartoon” or “cute character” at all. Instead:
- “stylized character illustration”
- “graphic simplified character design”
- “flat character icon with expressive pose”
Then reintroduce very specific cartoon behaviors, like:
stylized character illustration, simplified anatomy, three fingered hands, big expressive eyes, flat limited palette
You dodge the model’s default and rebuild your own “cartoon” from parts.
3. Use camera language to differentiate style
Most AI cartoons feel generic because the “camera” is generic: medium shot, straight-on, neutral perspective.
Force unusual framing:
- “extreme low angle, character towering over viewer”
- “wide cinematic shot, tiny character in huge environment”
- “fish eye lens distortion”
- “over the shoulder, focus on background”
Combine that with style:
stylized character, extreme low angle shot, warped perspective, flat cel shading, limited muted palette
Same character design, different camera language, and suddenly it does not read as stock mascot art.
4. Lock a strict color system
Instead of “vibrant colors,” define rules like a real production bible:
- One global accent color (for example: neon red).
- One global shadow color (for example: desaturated indigo).
- Neutrals: only warm grays.
Prompt example:
character design, color system rule: warm gray neutrals, single accent color of neon red on clothing or props, all shadows tinted indigo, highlights slightly yellow, flat cel shading
Then enforce that rule across a whole batch. If the model drifts, correct it explicitly in the next run: “remove green tones, keep only warm grays and neon red accent.”
5. Treat text overlays and UI as part of the style
Most people only think of character + background. Add graphic design:
- Fake interface frames
- Speech bubbles with a specific shape
- Label strips at the bottom of the image
Prompt:
character portrait framed inside a thick rounded rectangle UI, small label at bottom with fake text, simple white speech bubble with jagged outline, flat vector style, limited palette
This gives your shots a “show card” or “trading card” feel that is way less generic, even if the drawing itself is simple.
6. Build a reusable base prompt and vary in layers
Instead of rewriting style from scratch each time, separate your prompt mentally:
- Style base (never changes for a project)
- World flavor (changes sometimes)
- Scene content (changes every time)
Example style base:
thick black outlines, flat cel shading, 1:2 head to body ratio, slightly oversized hands and feet, limited palette of muted colors, visible paper grain texture
World flavor for one series:
cozy urban fantasy, small apartments, potted plants, soft clutter, nighttime interiors with warm lamps
Then content:
witch roommate on a couch, hunched over laptop, tired expression
You keep your “DNA” stable, swap only the content. That is how studios keep a show’s look coherent even when the scenes differ wildly.
7. Do side‑by‑side diagnosis of what looks “generic”
Take 10 of your “meh” images, ignore subject matter, and write down:
- What the eyes usually look like
- What the mouths usually look like
- Shape of heads
- How backgrounds are treated
- How shading behaves
You’ll probably spot 2 or 3 repeated tendencies the model falls into, such as:
- Medium thickness, super clean vector outlines
- Perfectly centered characters
- Soft airbrush shading
Now actively ban those:
no soft airbrush shading, no centered composition, character off to the side, uneven hand drawn lines, slightly messy fill
This explicit “anti pattern” work is more effective than just piling more positive adjectives.
8. Use competitors in your head, not in the prompt list
You mentioned different AI art tools. Each one has its own “cartoon gravity.” Instead of fighting a tool’s default to the death, analyze its natural advantages:
- Tool A might handle thick line + flat color very well but fails at painterly shading.
- Tool B might give great texture but overcomplicates faces.
You can be pragmatic: generate clean character silhouettes in one tool, then feed those into another for texture. If you want, for instance, a style like “rough risograph zine,” use the first tool for pose and anatomy, then the second for grain, misprint vibe, and halftone.
9. Mild disagreement on “imperfection” as a magic bullet
I like the “wobble” and “off register” advice from @hoshikuzu, but it can become another cliché: “AI zine look” that still feels samey. Imperfection only works if you tie it to a reason:
- Is it supposed to feel like a kid’s drawing?
- A rushed storyboard?
- A photocopied office flyer?
Write that intent:
looks like a rushed storyboard frame, quick sketchy lines, partial erasures, minimal shading, timing notes scribbled in the corners
That narrative context pushes the model into a specific kind of imperfection instead of random jitter.
10. Pros & cons of treating your prompts like a “product title”
You mentioned trying to get more readable, structured prompts. Thinking of your main prompt chunk like a product title (short, highly descriptive, stable across images) actually helps:
- Forces you to be concise instead of stacking 20 style buzzwords.
- Easier to reuse and recognize what is doing the work.
- Improves consistency across a batch or “series.”
Cons
- Can tempt you into formulaic phrasing that you never question.
- If your base “title” is vague (“cute cartoon character”), you just lock in genericness.
- Harder to explore radically different looks without rewriting that entire core.
Treat that “title” as something you refactor every few days, not sacred text.
If you want targeted help, post one of your current prompts and a single output. I’d strip it down to a 2–3 line “style bible” for you and show how to pivot it without just cramming more adjectives in.
