I accidentally used Shift Delete on important files stored on my USB drive, so they didn’t go to the Recycle Bin. The drive has photos and work documents I really need back, and I’m scared of making things worse by using the wrong recovery method. What’s the safest way to recover deleted files from a USB flash drive after permanent deletion?
Deleting files from a USB drive is a different mess than deleting stuff from your main PC drive. The usual 'check the Recycle Bin' tip often goes nowhere, because most flash drives do not use the normal Windows Recycle Bin. You hit delete, and Windows often treats it like the file is gone on the spot.
Still, I would not write it off yet. In a lot of cases, the data is still sitting on the USB. The file entry gets removed from view, and the storage space gets marked as free. The problem starts when you keep copying new stuff onto the drive. New data overwrites old deleted data, and from there recovery drops from doable to ugly fast. Small USB drives leave you less room for mistakes. I learned this the annoying way.
If this were my drive, I would start with data recovery software, unless the USB has hardware trouble. What I mean is stuff like this:
- the computer does not detect the USB at all,
- it shows 0 bytes or some random wrong size,
- it drops connection when you move it a little,
- the connector looks bent, loose, or cracked,
- the drive gets hot for no good reason,
- the files matter enough where you do not want to risk a home fix.
If none of those fit and the drive still shows up like normal, software recovery is the route I would take.
Before scanning, do the quick low-effort checks. I always look through the PC first, then cloud folders, email attachments, and any backup folders in case I copied the files earlier and forgot. Also turn on hidden files and look at the USB again. I have seen files look 'deleted' when they were only hidden by a bad attribute change or some junk malware. It is also worth checking for folders named $RECYCLE.BIN, RECYCLER, RECYCLED, or .Trashes if the drive touched a Mac at some point. I would not count on this fixing everything, but it takes little time.
Once those checks fail, scan the drive. Most recovery apps differ in layout and file support, but the flow is close enough:
- Install the recovery app on your computer, not on the USB drive.
- Connect the USB drive.
- Pick the USB inside the recovery app.
- Start a deleted or lost file scan.
- Let the scan finish. Do not cut it short unless the drive is dying.
- Use filters, search, or file groups to trim the list.
- Preview files when the app supports it.
- Save recovered files to your computer, external HDD, SSD, or another USB, never back to the same USB drive.
That last step matters more than people think. If you restore files onto the same flash drive, you risk overwriting other deleted files you have not recovered yet. I have seen people do this once, then spend the next hour wondering why round two found less stuff. Yeah, because the drive got written to again.
For the recovery app itself, Disk Drill would be the first one I would try. I have used a pile of these tools over the years, and for a normal deleted-file case on a USB stick, this one is easier to deal with than most. It handles common USB file systems like FAT32, exFAT, and NTFS, the interface is clean enough, and the preview feature saves time. If a file previews fine, I usually take that as a strong sign the recovered copy will be usable too.
It also helps in cases where the file system is partly damaged or missing directory info. It is not limited to old folder records, because it also looks for file signatures. So even if the original filename is gone, you still might get the file back under a rebuilt result with a generic name. Messy, but better than nothing. I have taken messy over gone plenty of times.
The other option worth naming is PhotoRec. It is free, and yes, it pulls off some good recoveries, especially when the file system is trashed. But using it feels rough. The interface is old-school in the bad way, and recovered files often come back without original names or folder structure. It works. I am not saying it does not. I am saying you might end up sorting through thousands of mystery files by hand, and that gets old fast. Ask me how I know, lol.
I would skip CHKDSK at this point. People throw it into every recovery thread, and I get why, but it is a repair tool, not an undelete tool. It changes file system structures. Before recovery, that is not where I would start. My rule has stayed the same for years, recover first, repair later.
So, plain answer. Stop using the USB. Check hidden files, recycle-style folders, backups, cloud copies, and email attachments. If nothing turns up, scan the drive with Disk Drill and save recovered files somewhere else. If the USB acts unstable or looks physically damaged, I would skip DIY and hand it off to a recovery lab.
First thing, stop touching the USB. No copying, no moving files, no format prompt, no error-check tool. Every write cuts recovery odds.
I agree with @mikeappsreviewer on one big point, recover first. I differ a bit on the hidden-file check being worth much for Shift Delete. For a true Shift Delete case, I’d spend less time poking around and more time making a sector-by-sector image of the USB if the files matter a lot. Clone first, scan the clone. That gives you one clean shot if the stick starts acting weird later.
Best order I’d use:
- Plug it in once.
- If it reads fine, make an image with a recovery tool.
- Scan the image, not the original drive.
- Recover to your PC or another drive.
- Sort by file type and date.
If you want the easy route, Disk Drill is a solid pick for USB deleted file recovery. It handles exFAT, FAT32, NTFS, and previews photos/docs well. Preview matters. If a JPG or DOCX opens in preview, recovery odds are usuallly better.
If Disk Drill misses filenames or folders, try PhotoRec after it. I only use PhotoRec as a second pass because the file names come back like a train wreck. Great for photos, bad for your sanity.
Skip CHKDSK for now. I disagree with people who run repair tools first. That’s how files turn into more of a mess.
If you want a quick visual walkthrough, this pen drive data recovery video guide helps:
watch this quick USB flash drive file recovery video
If the USB disconnects, shows wrong size, or gets hot, stop DIY stuff. That’s lab territory.
Shift Delete on a USB is bad, but not always game over. One thing I’d add to what @mikeappsreviewer and @nachtschatten said: check whether the files were ever opened recently on your PC. For Office docs, PDFs, even some photo editors, you can sometimes pull copies from Recent files, temp folders, autosave, or app cache. It’s not “real” USB recovery, but it has bailed me out before when the deleted original was toast.
Also, I’m a little less obsessive about cloning first for every normal USB case. If the stick is stable and detected properly, I’d try a read-only style scan right away. If it’s flaky, then yeah, image it first. No need to turn a simple recovery into a whole lab project unless the drive is acting sus.
My order would be:
- stop using the USB imediately
- do not run repair tools or format
- check app temp/autosave locations on the PC
- look in Windows File History or OneDrive version history if those files were synced before
- then run Disk Drill on the USB and recover files to your computer, not back to the stick
Disk Drill is probly the easiest option here for deleted files from a USB flash drive, especially for photos and documents because previews help you avoid restoring junk. If filenames come back messy, at least you can sort by type/date and salvage the important stuff first.
If you want more ideas from other people dealing with USB file loss, this Facebook discussion about pen drive data recovery tips is worth a skim.
If the USB starts disconnecting or asks to be formatted, stop. That’s where DIY recovery gets real dumb real fast.
One angle the others only touched lightly: check the Windows machine itself for traces before you go all-in on raw USB recovery. Not hidden files on the stick, I mean local leftovers.
Things I’d check:
- Office AutoRecover folders for Word/Excel docs
- Recent Files lists in the apps that opened them
%temp%and app-specific cache folders- Photoshop, PDF editors, photo managers, etc.
- OneDrive or Google Drive local sync history if you ever dragged copies around
I slightly disagree with cloning first as a rule for every healthy USB. If the drive is stable, detected correctly, and not dropping out, a normal scan is fine. Cloning is smartest when the stick is flaky, slow, or physically suspicious.
As for tools, Disk Drill makes sense here.
- easy to sort photos and docs
- preview is actually useful
- supports common USB file systems
- good for quick triage
- deep scans can return messy filenames
- free recovery is limited on Windows
- not magic if data was already overwritten
PhotoRec is still worth keeping in your back pocket if Disk Drill misses stuff, but expect chaos. @nachtschatten, @boswandelaar, and @mikeappsreviewer are right about one core thing though: recover to another drive only.
