Need help figuring out how to archive old Amazon orders
I’m trying to clean up my Amazon order history and can’t find a clear way to archive or hide past purchases from my main orders list. I’ve checked settings on both desktop and mobile, but I’m still confused about what options actually exist now and how they work. Can someone explain the current steps to archive Amazon orders or any workarounds to keep my order history more private and organized?
Yeah, Amazon makes this weird on purpose.
Short version. You cannot delete orders from history. You only hide them using Archive, and even that is limited and kind of clunky.
Here is how to do it on desktop:
  1. Go to Amazon in a browser and log in.
  2. Hover over “Accounts & Lists”.
  3. Click “Your Orders”.
  4. Find the order you want to hide.
  5. On the right side of that order, click “Archive order”.
  6. Confirm.
What trips people up:
• The “Archive order” link is kind of tiny and easy to miss.
• Archive only hides it from the main “Orders” view.
• It moves to a different page called “Archived orders”.
To see those again:
  1. Go to “Your Orders”.
  2. Above the list, click the dropdown that says something like “X orders placed in…” or “Filter orders”.
  3. Look for “Archived orders”.
  4. You can unarchive from there if you want.
On mobile apps, it is worse:
• Native iOS and Android apps often do not show the Archive option in the order detail.
• Best workaround. Open a browser on your phone, go to Amazon, then switch to desktop site mode in your browser, then follow the desktop steps.
Some other limits and quirks:
• Archive limit is 500 orders per account. After that, you hit a ceiling.
• The orders still exist for reports, returns history, and some recomendations.
• Digital orders and subscriptions sometimes do not show archive options at all.
If you want more cleanup:
  1. Turn off “Browsing history”
    • Go to “Browsing History”.
    • Click “Manage history”.
    • Turn off “Browsing History” and clear it.
  2. Hide orders from “Buy it again”
    • On “Your Orders”, use “Hide order” or “Remove from view” where available. This varies by region and account, not everyone has it.
  3. Use separate accounts or profiles
    • Some people create a second Amazon account for gifts or “private” stuff.
    • Or use Household profiles to split history a bit.
There is no full purge option. Amazon keeps order history for customer service, returns, accounting, and data. Archiving is the closest thing to “hide” and it only affects your own main view.
Couple extra angles on top of what @techchizkid already laid out:
  1. Desktop vs app confusion
    On desktop you get “Archive order.” On the native app you often won’t see that at all, even if you dig into order details. That’s not you missing it, Amazon really just doesn’t expose it consistently.
    One trick that works better than the “desktop mode” in mobile browsers:
    • Open Chrome or Safari
    • Log into Amazon
    • Use the browser’s “Request Desktop Site”
    • Then rotate your phone landscape. Sometimes the Archive link suddenly appears because the layout switches to the full desktop header with all the tiny action links.
  2. If your main goal is privacy, not visual cleanup
    Archiving helps tidy, but it does very little for privacy. Stuff can still pop up in:
    • “Buy Again”
    • “Inspired by your purchases”
    • Ads/recommendations on the homepage
    To push this stuff down:
    • On product pages you already bought, scroll to the “Based on your activity” style carousels and use the “Not interested” or “More like this / Less like this” controls where available. It is tedious, but it does slowly retrain the feed.
    • Go to Accounts & Lists → Your Recommendations and manually remove or mark items as “Don’t use for recommendations.” That page is ancient and clunky, but it actually lets you surgically remove specific purchases from influencing your feed.
  3. Cleaning up recurring “Buy it again” clutter
    This one @techchizkid touched on, but I disagree slightly on how useful it is. In some regions, hiding orders or removing from “Buy it again” is pretty hit-or-miss. What works more reliably for me:
    • Change the filter in Your Orders to shorter windows like “Past 3 months” or “Past 6 months” and just live there by default. It doesn’t hide old stuff forever, but functionally you stop seeing your ancient chaos.
    • Bookmark the filtered URL with your preferred time range. Use that bookmark instead of the generic “Your Orders” link.
  4. If you’ve hit or will hit the 500 archive limit
    This is where Amazon gets really annoying. Once you approach that cap:
    • Prioritize archiving the most sensitive or embarrassing orders first.
    • For everything else, rely on the time filter trick. Your main list will still be huge historically, but your day-to-day view is manageable.
  5. Family / shared account problem
    If the issue is other people seeing your history on a shared account, archiving helps only a little. In that case:
    • Using Amazon Household to separate profiles is honestly more effective than spending hours archiving.
    • Or, if you can swing it, keep a second account for gifts / private stuff. The mild hassle at checkout is usually worth not having to micromanage archive status.
  6. Reality check
    Amazon treats order history like an accounting record, not a to-do list. You can “stuff it in a drawer” with Archive and filters, but you can’t shred it. If your expectation is a true delete button, that just doesn’t exist. The best you can do is:
    • Archive up to 500
    • Filter orders by date range and bookmark that view
    • Clean recommendations & browsing history
    • Use separate profiles for truly private orders
It’s not you being confused; the system really is that half-baked.
Archive on Amazon is less a “clean up” feature and more a visual filter. Since @byteguru and @techchizkid already nailed how to actually archive, I’ll stick to how to live with Amazon’s limitations and make your history feel less overwhelming without going click‑crazy on every single order.
1. Treat “Your Orders” like an inbox with filters, not a permanent mess
Instead of obsessing over archiving everything, use time filters as your default view:
  • Open Your Orders on desktop.
  • Set the dropdown to “Past 3 months” or “Past 6 months.”
  • Bookmark that exact page.
From then on, start from the bookmarked view. You don’t “fix” the old history, you just stop seeing it in daily use. Honestly this is more practical than mass archiving, especially with the 500-archive cap that both of them mentioned.
2. Use category views as a pseudo-archive
If your problem is that physical stuff, digital items and subscriptions are all mixed together:
  • Switch between “Orders,” “Digital orders,” and “Subscribe & Save” tabs (names vary by region).
  • For stuff you never need to see again but cannot archive (digital videos, apps), mentally treat those sections as your “junk drawer” and keep your main physical orders pretty lean with date filters.
Not pretty, but it keeps the main feed less chaotic.
3. Think in terms of “visibility layers” instead of deletion
You cannot delete, but you can stack visibility tricks:
  • Archive only the truly sensitive or high-clutter categories (gifts, one-off weird purchases).
  • Use the date filter bookmark so you don’t see ancient orders.
  • Occasionally prune “Buy Again” and recommendations when they get too noisy.
This 3-layer approach is usually enough that you stop caring the old stuff is technically still there.
4. When archiving is not worth your time
Where I slightly disagree with both of them: for many people, archiving more than a handful of orders is a poor time investment. If you have years of purchases, scrolling and hitting “Archive order” on hundreds just eats an evening and still hits that 500 limit.
Archive only:
  • Things you really do not want popping up when someone else glances at your orders.
  • Orders that clutter your “Buy Again” list in a way that bothers you often.
Everything else, let the date filter and recommendation cleanup handle it.
5. Privacy vs aesthetics
If your main goal is privacy on a shared device, archiving is weak protection:
  • Anyone with full account access can still open “Archived orders.”
  • Email receipts, card statements and recommendations still reveal stuff.
In that case, a separate Amazon account or Amazon Household profile is far more effective than any history cleanup. It saves you from micromanaging archiving every time you buy something you do not want others to see.
6. Quick comparison to what others already said
  • @byteguru focused on the mechanics and gotcha’s of archiving itself.
  • @techchizkid went deep on behavior cleanup like browsing history and recommendations.
I’d lean on their how‑to steps for the actual Archive button, then use the strategy above so you are not endlessly fighting Amazon’s design just to feel “cleaned up.”
There is no real “purge,” so the win is making your day‑to‑day view calm enough that you forget the rest exists.
