Need help finding a reliable Google Map embed code generator
I’m trying to embed a custom Google Map on my website, but I’m confused about which Google Map embed code generator I should be using and how to get the code set up correctly. Some tools I found either don’t work with my site builder or create code that doesn’t display the map at all. Can anyone recommend a trusted Google Map embed code generator and explain the basic steps to generate and insert the embed code so it shows up properly on a responsive web page?
Short version. Stop using random “Google Maps embed generators”. Use Google’s own tools or the official Maps Platform.
Here is the practical route.
  1. Easiest no-API-key way
    If you only need to show a place or basic map.
  1. Go to maps.google.com.
  2. Search your address or place.
  3. Click “Share”.
  4. Go to the “Embed a map” tab.
  5. Pick size.
  6. Copy the iframe code.
  7. Paste into your page HTML where you want the map.
Example:
This works well if you do not need styling, custom markers from data, or traffic layers.
  1. When you need custom features
    If you want multiple custom markers, custom styles, or control over zoom and behavior, use Google Maps Platform.
Steps:
  1. Go to https://console.cloud.google.com
  2. Create a project.
  3. Enable “Maps JavaScript API”.
  4. Go to “APIs & Services” → “Credentials”.
  5. Create an API key.
  6. Restrict the key to your domain under “Application restrictions”.
  7. Restrict to “Maps JavaScript API” in “API restrictions”.
Example code:
  1. About those 3rd party “embed generators”
    Most of them either:
• Still rely on the same official iframe Google gives you.
• Add tracking or extra scripts you do not need.
• Break when Google changes URLs or parameters.
• Do not handle billing or API keys, so you get errors like “For development purposes only”.
If the ones you tried did not work on mobile or with your builder, it is usually:
• They wrap the iframe in extra code.
• They inject http content inside https pages.
• They load from their own domain, which some browsers block.
  1. If you use a CMS or builder
    • WordPress: use the “Custom HTML” block and paste the Google Maps iframe from the Share → Embed tab.
    • Wix / Squarespace / Webflow: same idea, use their “embed code” element and paste the iframe.
    • Do not use “visual” map addons unless you need them. They often break or add bloat.
  2. Common gotchas
    • Map not showing at all
  • Check for mixed content. Page should use https and iframe src should start with https.
    • Grey map with “for development purposes only”
  • That is from the JS API, not the simple iframe. Your API key is not set up with billing or restrictions.
    • Scroll and zoom not working well on mobile
  • Wrap iframe in a responsive container and set width to 100 percent and a fixed height.
Basic responsive example:
If you share what you need exactly, like “one static location” or “multiple custom points from a list”, you get a more precise code snippet.
You’re tripping over the word “generator” here. The “generator” is really just: where does the iframe or JS snippet come from, and how much control do you need.
@voyageurdubois already covered the two sane options (native iframe and official JS API). Let me poke at the in‑between cases and the stuff that usually goes wrong.
1. If you want a custom map (multiple pins, saved places) without JS code
Use Google’s My Maps instead of random generators:
  1. Go to https://www.google.com/mymaps
  2. Create a new map, add your markers, layers, colors, etc.
  3. In the map’s menu choose “Embed on my site”
  4. Copy the iframe Google gives you
That iframe is still “no API key,” but more flexible than the single-place embed from the normal Maps site. Most “embed generators” are just repackaged versions of this with ads/tracking sprinkled in.
2. If your page builder is being picky
A lot of “doesn’t work with my builder” issues are:
  • Builder strips <script> tags
  • Builder sanitizes certain attributes
  • Builder only likes iframes and chokes on custom JS
In that case, forget JS APIs. Stick to:
  • Regular Maps “Share → Embed” iframe
  • Or My Maps iframe
Both are pure HTML, so builders usually accept them. If the builder has a “map widget” that asks for an API key and generates code for you, I’d personally avoid that unless you know how to swap API keys or debug it later.
3. Why I’d skip most 3rd‑party generators
Slight disagreement with the very strict “never use them” take: they’re not always evil, but they are usually:
  • Adding parameters that will silently break when Google changes stuff
  • Injecting their own domain as a proxy, which can cause CORS or CSP issues
  • Slapping analytics or branding into your map
Given you already hit “some tools don’t work with my …”, that’s textbook sign those generators are doing too much.
4. If you really need custom behavior but not full-blown code
There’s a middle path:
  • Use the official JS API like @voyageurdubois showed
  • Then grab a minimal starter from Google’s own examples and tweak only the parts you need: center, markers, zoom
  • Ignore random “no-key customizer” sites that promise styling without API keys. Those are often violating Google’s ToS and break later.
5. Quick checklist to pick your route
  • One address, no special styling → Standard Maps “Share → Embed” iframe
  • Multiple pins, custom colors, but no real coding → Google My Maps iframe
  • Dynamic data, programmatic markers, fancy behavior → Maps JavaScript API with your own key
If you tell what “custom” means in your case (a couple locations vs dynamic data from a DB vs custom styles) you’ll land on one of those three and never need a sketchy generator again.
