Need help with my Sony ULT Field 5?
My Sony ULT Field 5 suddenly stopped working the way it should, and I can’t figure out if it’s a battery, pairing, or sound issue. I’ve already tried the basic troubleshooting steps, but nothing has fixed it. Looking for advice from anyone who knows common Sony ULT Field 5 problems and how to get it working again.
Start with the boring stuff, but do it in order.
  1. Hard reset the speaker.
    Hold Power and Bluetooth for about 7 to 10 seconds. Wait for the shutdown tone. Turn it back on. Sony speakers get weird firmware hiccups, and a reset fixes more stuff than it should.
  2. Check battery behavior.
    Plug it into a known good USB-C charger for at least 30 minutes. Use a wall brick, not a laptop port. If the charge light blinks oddly or never goes solid, battery or charge board is suspect. If it turns on only while plugged in, battery is the first thing I’d blame.
  3. Kill old pairings.
    Delete the ULT Field 5 from your phone’s Bluetooth list. On the speaker, clear pairing history if reset did not do it. Then pair with a different phone. This matters. If Phone A fails and Phone B works, your speaker is fine and your phone is the problem.
  4. Test audio sources.
    Play audio over Bluetooth, then with a wired source if you have one. Also try system sounds, not Spotify only. Apps bug out. If it connects but you get no sound, check phone volume, speaker volume, and absolute volume in Bluetooth settings.
  5. Check for firmware in Sony Music Center.
    If the update failed before, the speaker sometimes acts dumb after. Reinstall the app if needed. Yeah, Sony software is kinda janky sometiems.
  6. Watch the LEDs.
    No lights at all, power issue.
    Lights, no pairing, Bluetooth board or firmware issue.
    Pairs, no sound, amp or DSP issue.
    Distorted sound at all volumes, driver or amp issue.
If you already did all this and it still acts up, I’d lean hardware. Battery if power is flaky. Main board if pairing and audio are both messed up. Speaker driver if sound is crackly on every source.
I mostly agree with @suenodelbosque, but I would not jump straight to blaming the battery unless the speaker is actually shutting off or refusing to hold charge. On these Sony portables, weird behavior can also come from the app stack and multipoint acting stupid.
A few things I’d check that are a little different:
  • Turn off multipoint if it’s enabled. If the speaker keeps trying to juggle two devices, audio can get flaky or seem “dead.”
  • Test it from a device with all audio enhancements off. On some phones, Dolby, EQ, volume leveling, etc can make the speaker sound broken when it’s not.
  • If one channel sounds weak or the bass vanished, try ULT mode on/off. Sometimes the DSP gets wonky and it sounds like a blown driver even when it isnt.
  • While charging, feel the back near the USB-C area. If it gets unusually warm but barely charges, that points more to charge circuit than battery.
  • Do a call audio test if your phone allows it. Media audio failing but call audio working is usually software/path related, not a dead speaker.
If it powers on, pairs, and the buttons respond, the main board probably isn’t fully toast. If sound is crackly on every source at low volume too, then yeah, hardware starts looking real. Sony stuff can be annoyngly half-broken like that.
I’d go one layer lower than what @suenodelbosque mentioned and treat this like a state corruption problem first, not a dead part. On the Sony ULT Field 5, the weird failures I’ve seen most often are:
  1. Bluetooth profile stuck
    Delete the speaker from every previously paired phone/tablet nearby, not just your main one. Then power the speaker off for a full minute before pairing again. If an old device keeps trying to reclaim it, behavior gets inconsistent.
  2. Charging source issue
    I actually disagree with people who assume “charging = battery fine.” Some USB-C bricks negotiate badly with portable speakers. Try a plain 5V charger and a different cable, not a laptop port.
  3. Moisture or protection lock
    If it was used outdoors, near a pool, or in humidity, let it sit completely dry overnight. Sony portables can act half-alive when protection circuits kick in.
  4. Factory reset, then test with AUX/USB audio if available
    The key is testing a non-Bluetooth source. If Bluetooth is bad but wired/direct playback works, it narrows it fast.
Pros of the Sony ULT Field 5: strong bass, good volume, rugged build.
Cons: app/settings weirdness, Bluetooth behavior can be finicky, troubleshooting is more annoying than it should be.
If it powers on normally but has distorted or missing sound across all sources, that’s when I’d start suspecting hardware, especially driver or amp section.
