Need help with my Superbox S6 Max
My Superbox S6 Max suddenly stopped working the way it should, and I’m not sure what caused it. I’ve tried the basic troubleshooting steps, but I still can’t get it to stream properly or respond normally. I need help figuring out what’s wrong and how to fix it so I can use my device again.
Start with the simple stuff, because these boxes fail in boring ways.
  1. Full power cycle. Unplug the Superbox and the TV. Pull power for 2 minutes, not 10 seconds. Plug the box back in first.
  2. Check network. Run a speed test on the box if it still opens apps. For stable streaming, you want at least 25 Mbps for HD, closer to 50 Mbps if your WiFi is crowded.
  3. Switch from WiFi to ethernet if you have the port open. This fixes a lot of random buffering and menu lag.
  4. Clear app cache. Go into Settings, Apps, pick the streaming app, clear cache. If one app is broken, clear data too, but you will need to sign back in.
  5. Check storage. If internal storage is almost full, the box starts acting dumb. Delete unused apps.
  6. Reboot your router. People skip this and then wonder why the box is ‘suddenly broken.’
  7. Try a diff HDMI port and cable. Bad HDMI handshakes cause black screens and weird freezes.
  8. If the whole system is laggy, do a factory reset. Back up logins first.
If it still won’t stream properly after all of ths, post 3 things. What version it’s on, whether ethernet changes anything, and whether the issue is every app or only one. That narrows it down fast.
If the basics are already done, I’d stop treating it like “just buffering” and figure out whether it’s a control issue, a video issue, or an app issue. @sognonotturno already covered the usual reset/cache/network stuff, so I’d look at these:
  • Check the remote first. Weak batteries can make the box seem frozen when it’s really just missing inputs.
  • If menus are stuttering even on the home screen, that points more to system instability than internet.
  • Turn off any display matching / auto resolution options if your TV supports weird refresh switching. I’ve seen boxes get flaky from bad resolution handoffs, not just HDMI cables.
  • If audio works but video hangs, try forcing 1080p instead of 4K temporarily.
  • Look for overheating. If the box feels hot as heck, shut it down and move it somewhere with airflow.
  • I actually wouldn’t rush to factory reset unless you know the problem is on the box itself. Sometimes that just wastes time.
Also, when you say “stopped working properly,” what exactly happens? Freezes, black screen, reboot loop, apps crash, remote lag, no sound? That part matters alot.
I’d go one layer deeper than @sognonotturno here and check whether the box is failing at boot or only when DRM/video playback starts.
A few things that get missed:
  • Test with another power adapter if you can. Low or unstable power causes weird freezes, app crashes, and random reboots.
  • Unplug all USB devices, SD cards, and even Ethernet for one clean boot. Bad peripherals can hang Android boxes.
  • Check storage space. If internal storage is nearly full, streaming apps can act broken even when the network is fine.
  • See if the date/time is wrong. That can break app logins and some streams.
  • Try one known-safe app like YouTube. If that works but your main streaming apps do not, it’s probably app-side, not total box failure.
I slightly disagree on delaying a factory reset too long. If the Superbox S6 Max boots normally, has good power, enough storage, and still behaves badly across multiple apps, a reset is sometimes the fastest divider between software corruption and hardware trouble.
Pros for the ‘’: can restore normal behavior fast, clears junk bugs.
Cons for the ‘’: wipes logins/settings, won’t fix overheating, bad power, or failing hardware.
If you can, post the exact symptom chain: boots to home, opens apps, then freezes? Or black screen right after launch? That’ll narrow it down fast.
