Need help writing clear prepositional phrases in sentences
I’m struggling to write clear prepositional phrases in my essays and keep mixing them up with other parts of speech. It’s affecting my grammar, and I’m losing points on assignments. Can someone explain how to identify and use prepositional phrases correctly, with a few simple examples I can practice from?
Quick way to keep prepositional phrases straight:
  1. What a prepositional phrase is
    Preposition + object (usually a noun or pronoun) + any modifiers.
    Common prepositions:
    in, on, at, by, for, from, of, to, with, under, over, during, after, before, between, among, about, around, through, without, within.
    Examples:
    • in the house
    • on the table
    • after the exam
    • with my friends
    • during the meeting
  2. How to spot one
    Step 1: Find the preposition.
    Step 2: Ask “preposition + what / whom”.
    The answer is the object of the preposition.
    Everything from the preposition up to that object is your prepositional phrase.
    Example:
    She sat on the chair by the window.
    on the chair → on what → chair
    by the window → by what → window
  3. What a prepositional phrase does
    It acts like an adjective or an adverb.
    Adjective phrase (describes a noun):
    • The book on the table is mine.
    on the table describes book.
    Adverb phrase (describes verb, adjective, or adverb):
    • She worked in the library.
    in the library tells where she worked.
  4. How to avoid mixing it with other parts of speech
    a) Do not confuse with verbs
    Prepositions never work as the main verb of the sentence.
    Wrong: He in the room.
    Right: He is in the room.
    in the room is a phrase. is is the verb.
    b) Do not confuse with conjunctions
    A conjunction links equal things.
    A preposition starts a phrase and has an object.
    Example:
    Before we ate, we talked.
    Before is a conjunction here, followed by a clause we ate.
    Before dinner, we talked.
    Before dinner is a prepositional phrase. dinner is the object.
    Quick test. If the word is followed by a noun or pronoun only, it is usually a preposition.
    If it is followed by a full subject + verb, it is usually a conjunction.
  5. Common essay trouble spots
    a) Stacking too many phrases
    Example:
    The results of the study on students in the city with limited access to resources show…
    Better:
    The study focused on city students with limited access to resources. Its results show…
    Aim for no more than two prepositional phrases in a row in formal writing, unless you have a strong reason.
    b) Unclear reference
    Example:
    I discussed the problem with the teacher in the email.
    Who was in the email, you or the teacher or the problem
    Fix by moving the phrase closer to what it modifies.
    I emailed the teacher about the problem.
    or
    In the email, I discussed the problem with the teacher.
  6. Quick practice trick you can use on your essays
    Step 1: Print or open your draft.
    Step 2: Circle all prepositions.
    Step 3: Underline their objects.
    Step 4: Draw a box around each full phrase.
    Step 5: For each phrase, write “Adj” or “Adv” in the margin.
    If you cannot label what the phrase describes, the sentence is probably unclear or awkward.
  7. How to score higher on assignments with this
    Teachers look for:
    • Clear subjects and verbs.
    • Controlled use of modifiers.
    • Few long chains of prepositional phrases.
    So when you edit, check three things:
    • Is the subject clear if you remove every prepositional phrase
    • Does each phrase sit right next to what it describes
    • Are any phrases unnecessary
    Example edit:
    Original:
    The argument in the article about technology in schools for students in lower income areas with fewer resources is strong.
    Step 1, find subject and core verb.
    The argument … is strong.
    Step 2, simplify phrases.
    The article presents a strong argument for using technology in schools that serve lower income students with fewer resources.
  8. If you use AI tools for drafts
    Some AI output sounds stiff, with too many prepositional phrases and odd word order.
    If your teacher flags AI tone, you might want a tool that smooths that out.
    Something like Clever AI Humanizer for natural sounding writing helps rewrite AI text so it sounds more like a human wrote it, with cleaner phrases and fewer awkward preposition stacks.
    Still do the preposition check after, but it cuts some of the robotic feel.
  9. Quick cheat sheet
    Structure: PREPOSITION + OBJECT
    Roles: adjective phrase or adverb phrase
    Tests:
    • Preposition + what or whom
    • Remove the phrase, sentence still has subject + verb
    • If followed by subject + verb, it is more likely a conjunction, not a preposition
If you want, drop a couple of your own sentences and people here can mark the prepositional phrases so you see the pattern faster.
You’re definitely not alone. I used to butcher prepositional phrases so badly my professor wrote “Where is your sentence’s spine?” in red pen.
@ombrasilente already gave a super clean breakdown of what they are and how to spot them, so I won’t repeat that whole system. I’m gonna come at it from a different angle: how to feel where the prepositional phrase begins and ends, and how to keep it from wrecking your sentence.
1. The “spine test”
Before you even worry about prepositional phrases, find the spine of your sentence:
subject + main verb + (core complement)
Example:
  • The students in the library with laptops during the exam were cheating.
Strip out everything that feels like extra info:
  • The students were cheating.
Whatever is left is usually your core. Almost everything you removed is modifiers, and a ton of those are prepositional phrases. This helps you:
  • Stop mistaking prepositions for verbs
  • See if your main grammar is okay before the phrases pile on
If you remove some words and the sentence collapses completely, you probably cut the verb or subject, not a prepositional phrase.
2. “Can I move it?” trick
Prepositional phrases are usually mobile. You can often move them around without breaking the core structure.
During the exam, the students were cheating in the library.
The students were cheating in the library during the exam.
In the library, the students were cheating during the exam.
If a chunk of words can move as a unit like that, and nothing essential about subject/verb changes, it’s very likely a prepositional phrase (or another type of modifier).
If it cannot move easily without sounding wrong, it might not be a prepositional phrase, or it might be tightly attached in a weird way that hurts clarity.
3. How not to mix prepositional phrases with other stuff
Instead of repeating @ombrasilente’s tests, here are a few different signals:
a. Watch out for “fake” prepositions in phrasal verbs
Sometimes a word that looks like a preposition is really just part of the verb:
  • She looked up the word.
  • They ran into trouble.
Here, “up” and “into” are not starting prepositional phrases. There is no “object of the preposition” as a separate little noun chunk.
Compare:
  • She looked up in the dictionary.
“in the dictionary” is a prepositional phrase. “up” is stuck to “looked” as part of the verb.
Quick check:
If you can move the “preposition” and keep the meaning, it might be a phrasal verb:
  • She looked the word up. :white_check_mark:
    That means “up” is not the start of a prepositional phrase.
This is one place I slightly disagree with how simple some explanations make it. “Preposition + noun” is great, but English phrasal verbs are gremlins and will mess with that rule.
4. Clean prepositional phrases vs. messy ones
You’re worried about clarity, especially in essays. The problem is usually not recognizing prepositional phrases, it’s letting them pile up into a mess.
Compare:
In the article about education in urban areas with high poverty rates in the United States, the author argues…
This is “correct” but ugly. Try:
  1. Keep no more than 1–2 prepositional phrases right after each other.
  2. Upgrade some to other structures.
Better:
In the article on education in high-poverty urban areas in the United States, the author argues…
Even better, split it:
The author’s article focuses on education in high-poverty urban areas in the United States. He argues that…
You’ll still have prepositional phrases, but they won’t choke the main idea.
5. Fast editing routine for your essays
Different from @ombrasilente’s circle-and-label approach, here’s a quicker “in your head” version you can do while reading:
  1. Read the sentence out loud.
  2. When you hit a preposition (in, on, at, for, from, about, etc.), pause and ask:
    • “Is this detail essential or just extra?”
  3. If it’s extra, check:
    • Is it next to the word it’s describing?
    • Could I move it to the beginning or end without confusion?
    • Could I replace it with a stronger verb or adjective?
Example:
The explanation in the paper about climate change for students in middle school is confusing.
Mentally fix:
  • Main spine: The explanation is confusing.
  • Prepositional clutter: in the paper / about climate change / for students in middle school
Rebuild it:
The paper’s explanation of climate change is confusing for middle school students.
Same meaning, way clearer.
6. One more identification hack: stress pattern
If you read your sentence aloud and naturally stress certain words, prepositional phrases often sound like lower-stress “tail” parts:
The ARGUment / in the ARticle / about techNOLogy / in SCHOOLS
If your stressed, important words are buried deep inside a long chain of prepositional phrases, your sentence will feel muddy. The fix is often to:
  • Turn some prepositional phrases into adjectives:
    “policies for the environment” → “environmental policies”
  • Turn them into verbs:
    “an analysis of student behavior” → “analyzes how students behave”
This is less about grammar rules and more about style and clarity.
7. About tools (since you mentioned essays & grades)
If you ever use AI to draft or brainstorm, that’s honestly where a lot of horrible prepositional stacks come from. The text sounds formal but ends up like:
The impact of technology on learning in the context of modern educational systems in contemporary society…
If your teacher is already picky, that kind of thing just screams “awkward” or “possibly AI.” A tool like make AI writing sound more natural and human can actually help tone down those robotic chains of prepositional phrases and smooth the sentences out. Then you still run your own “spine test” and move/remove extra phrases, but you’re not starting from a wall of fluff.
If you want targeted help, drop 3 or 4 sentences from your essay where your teacher took points off. I can mark which chunks are prepositional phrases, which ones are unnecessary, and how to rewrite each so it’s both clear and grade-friendly.
Think of this as a troubleshooting session for sentences gone wrong.
1. A quicker way to spot the prepositional phrase
Forget the full analysis for a second and use this mechanical check:
  1. Find a common preposition: in, on, at, by, with, from, to, for, about, over, under, during, etc.
  2. Grab everything from that preposition up to the next noun or pronoun that makes sense with it.
Example:
  • in the library
  • with laptops
  • during the exam
If you remove each as a chunk and the sentence still has a working core, you have correctly identified a prepositional phrase.
Still a sentence, so the chunks are modifiers, not core parts.
I partly disagree with relying on “feel” alone, because when you are stressed in an exam, intuition fails. The mechanical chunk-removal test is safer.
2. Distinguish prepositions from similar-looking stuff
You said you mix prepositional phrases with other parts of speech. Here is a tight contrast:
Preposition + object (phrase):
in the library
for the exam
Subordinating conjunction (starts a clause):
because it was late
although they were tired
If the word is followed by a subject + verb (they were, it is, she goes), it is not starting a prepositional phrase.
Compare:
  • in the library → prepositional phrase
  • in that they were late → clausal connector, not a normal prepositional phrase for essay purposes
So check right after the word:
  • Preposition → followed by a noun or noun phrase
  • Conjunction → followed by subject + verb
3. Make them clearer by tightening what they attach to
A lot of messy grammar comments come from attachment confusion, not from having prepositions at all.
The teacher discussed the article about students with difficulties in class.
Who has difficulties: the students, the teacher, or the article?
Fix by moving or rewriting the prepositional phrase so its target is obvious:
  • The teacher discussed the article about students who struggle in class.
  • The teacher discussed the article in class with students who have difficulties.
When you edit, ask:
“Exactly which word does this phrase describe?”
If the answer is “uhh, kind of the whole thing,” then it is vague. Move it closer to the word you mean or rewrite.
4. Turn heavy prepositional chains into cleaner grammar
Instead of stacking them, convert some into adjectives or verbs.
Original:
The policy for the protection of data in online systems for schools is unclear.
Problems: multiple “of/for/in” chunks blur the message.
Possible revisions:
  • The data protection policy for school online systems is unclear.
  • The policy that protects data in school online systems is unclear.
When editing, look especially for “of” phrases:
  • discussion of the topic → discussion about the topic
  • protection of data → data protection
This alone removes a lot of clunky prepositional weight.
5. Quick self-check routine before you submit
Use this 3-step pass:
  1. Highlight all prepositions. Do it once on a paragraph. You will start to see your own habits.
  2. Circle any place with 3 or more in a row. Example:
    in the study of trends in education in urban areas
    That is a red flag.
  3. Try to rewrite each red-flag chain using:
    • adjectives: educational policy, environmental issues
    • verbs: analyzed student behavior → analysis of student behavior
    • relative clauses: which focuses on, who argues that
You do not have to kill all prepositional phrases. Just stop them from forming long trains.
6. On tools like Clever AI Humanizer
If you are drafting with AI or heavily rephrasing things, tools can accidentally pump out stiff, preposition-heavy sentences. Clever AI Humanizer can be useful to:
  • Smooth out overly formal chains like “in the context of” or “in relation to.”
  • Make sentences more natural and readable, which usually reduces unnecessary prepositional clutter.
  • Give you a version that feels closer to how people actually speak and write.
Cons
  • It will not always understand your teacher’s specific style expectations, so you still must apply your own grammar checks.
  • It can occasionally oversimplify academic tone if you are not careful.
  • If you rely on it too much, you might not build your own sense of where phrases should attach.
Use it as a second pass for readability, not a replacement for your own “spine + phrase” checks. Read what it outputs and still run the chunk-removal test.
7. How this fits with what @ombrasilente said
@ombrasilente already nailed the conceptual explanation and some excellent intuition tricks. I would just add:
  • Do not trust intuition alone; combine it with a mechanical test:
    preposition → grab chunk → remove → see if core survives.
  • Pay extra attention to what the phrase is modifying. Most grading comments come from unclear attachment, not from simply “using prepositions.”
If you want, post 2 or 3 of your own sentences that lost points, and I can mark:
  • each prepositional phrase
  • what it is supposed to modify
  • and one tighter rewrite for each sentence.
